N
Newsome3
Doing a periodic today and slight remedial works
mains is new 17th edition etc
on c/u sticker stating now cpc to lighting circuit
ive changed all fitting and screws to plastic.
What I'm wondering is what you'd fill in on periodic
code? Etc about this ciruit
Cheers
If all the fitting are class II then no code is required. A simple "observation" is all that is required IMHO
I personally would code it as C3, could be improved but not required. Also cover you better for not recording Zs and R1+R2 values.
Bloke I worked for before said he'd put code 1-2 as all cables are in walls not in trunking
also rcd problem with earth
Periodic
Electrician Talk
Thread Tags
Tags Tags
periodic
Newsome3,
HandySparks,
