clanky
Aug 16, 2018
60
33
1,193
Suffolk
Trainee Electrician
Business Name
Marine electronics
Nearing the end of my solar install (major works due to ground mount being over 60m away) and ive been pondering about options for the backup supply from the batteries. I obviously want to keep my 5 freezers and 3 fridges going in the event of a power cut (very common here in the sticks) but the 20A supply isnt really man enough for day to day usage when i use other equipment such as various tooling and large valve amplifiers.
So for days of heavy usage, i was thinking of a changeover switch with supplies from the batteries and the mains via henleys. (Please see picture) Question is, do i need the supply from the henleys fused? or can i just feed directly into the switch? The backup supply to the house is protected at the battery end of things via an RCBO on a consumer board and an MCB directly off the inverter. So can i feed this directly into the switch as well? The feedout supply from the switch will be going into a consumer board with an RCD incomer.
As ever thanks for any advice.
You need to give this some careful thought and planning as if you get the arrangement wrong you will have the dead mans loop where by the back up from inverter is trying to power the main grid supply from inverter.... you will get some really strange alerts on inverter with it likely doing a constant restart loop.
Assuming your attitude will be that you can manage without the heavy loads when the grid mains is off, then just split your installation between essential and non-essential boards.
  • Non-essential: direct off the mains, supplies heavy loads you can manage without
  • Essential: from the maintained output of the inverter/UPS unit, supplies the lighter loads you want to keep running off-grid
No need for a changeover switch - just two separate CUs, one direct off the mains incomer, one off the maintained output fo the inverter/UPS unit.
Suffolk
Trainee Electrician
Business Name
Marine electronics
Changeover Switches
UK
clanky,
Simon47,
