on switch boxes i just use the centre hole. tin hat on.
I use couplers and bushes to put boxes together, keeps them level, a standard gap and I can wire straight through.
Yep 20mm steel couplers and bushes, just have to make sure you knock out the right knock outs on the back boxes as sometimes only two sides of both boxes will line up to make them level.
My pet hate is gear with dual knockouts that when you knock the 20mm knockout, the 25 comes with it.
or, as I found the other day, an Schnieder board where the knockouts were harder than the surrounding material. Ended up drilling all of them.
thats why I carry around 25mm to 20mm reducers, drives me potty when that happens:rolleyes4:
and plastic boxes that split when you try and knock out the knockout bit.
I carry m20 washers to use if I do come across a larger hole that must be used. These can sandwich the larger hole, and if tight enough, they don't budge.
yeah. me too. hate cleaning the half melted plastic out of a hole saw.
