cliffed
The thing that frustrates me in this game,is electricians who still will not bend over cables for connection into equipment,I was taught anything up to 2.5mm needs to be bend over to provide a good connection,in a domestic environment,sockets light switches etc,how many times have you seen cables snapping off.Just wondering what your narks are,cheers
I never do this also dont see the point, ok if youve only got one core going into a terminal, what happens when you spur off a socket or doing a bit of two way lighting, gets a bit messy
other things bother me more, like late payers for one, and dry jobs with no tea oh and having my tools stolen.........and the worst of all.....twisted earths!!!
With the OP on the doubling over...
I do it whenever single cores are going in largish terminals eg radial/spur to socket or 2.5 in load of FCU - Also do it on switchgear (isolators etc) - don't normally do it on lighting
Usually depends on core/terminal size difference.
I may be a bit 'old school' on this but I was taught that way and it seems to me a more reliable termination method
I double over. Less than 6mm gets doubled always. I also double over 6mm into MCBs.
Yep...detest twisted earths!!! At least seperate sleeve and just twist the ends!!!
Late payers are my pet hate.
I'm going to put it out there, even though like others, depending on the core/terminal size I'm happy doubling over to make sure I have a secure connection.
When I was an apprentice the lad I worked with used to say "strictly speaking that doubling over exceeded the bending radius of the cables."
Strictly speaking it does - but also strictly speaking, it doesn't matter a hoot
Always double over if possible, good workmanship
At last someone who knows best,totally agree,mainly 1mm & 2.5 mm cabling,applies to having 1 cable at accessory ,switch cable ,any radial,etc,makes a good contact with screw,but the young lads out there,do not do it,each to their own,have a good day,cheers
