Discuss Pexman 42 BS to 6004/91 size? in the UK Electrical Forum area at ElectriciansForums.net
Luka
Hello everyone. I am trying to find out cable size used in my socket circuit. The only symbols I can see is Pexman 42 BS to 6004/91. Please advise what size it is and if it can be used in 32A radial circuit. Thank you
It's presumably old red and black colours and has '078/001 BASEC' written on it as well somewhere!
I suspect the only way of being sure is to measure the diameter of the copper with verniers (or a micrometer!) as accurately as you can, and from that work out the csa.
Reply to Pexman 42 BS to 6004/91 size? in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
