If you're running a 5c feed then a roll of black and grey single cost the same as brown, so it's a no-brainer.
Where using brown as purely the only colour in a 3ph distribution to 1ph outlet scenario can get muddled is simply in cable management and identification back at the feeder board - in which case your best friend isn't colour it's L1, L2 & L3 labelling on the brown conductor. That way, you've got the convention of brown and blue at the 1ph outlet (and in a large commercial setting one would hope the outlet itself would have a supply label on it anyway) and a clearer picture back at the board/s.
