Yes, I've tested the lamp with a direct feed and the lamp works fine. Looks like I will reduce the load and see if it switches. At first I thought it had to be faulty cells but have swopped them with the same results.
Anyway, thanks for your thoughts and I'll let you know the outcome!!
bluenose224,
bluenose224,
