We have 3 wall switches which control the hallway lights. The wiring is as the picture below I downloaded (which implies this is a fairly standard wiring arrangement). I'd like to replace one of the wall switches (either Switch 1 or Switch 2 in the diagram) with a PIR switch but I can't find a suitable wall-mounted PIR switch as the ones I've seen either require a Neutral and/or are simple on/off switches, whereas I think what's needed is a 3-(live)wire 2-way PIR switch, if such a thing exists. Can anyone advise on this and whether (and from where) such a PIR switch is available?
