P
Phillcbr400
Thought I'd ask here to see if anyone has any advice and knows more about this than myself.
Bathroom has been fully gutted and taken back to the brick. The plan is to have a paint finish everywhere bar the bath/shower and sink, which will be tiled.
Does the plaster need to have any form of waterproofing treatment etc?
fresh plaster needs to be sealed. This can be achieved with a weak PVA solution or watered down paint. If you slap neat emulsion over new plaster, it will suck all the water out of it and it will peel off.
Avoid pva , you'll be painting it forever. 50/50 water emulsion for first coat is best
I've been reading some treads about the net, regarding products there's a lot more out there than first thought. So many choices and not sure which direction to go.
Do what most/ all decorators do then, as billyhas said, 50/50 paint water base coat or two.
I was thinking maybe aquaboard the wet areas, then seal with a waterproof primer and tile. And the plaster can be made upto the same depth as the board. So all the same depth with tiles on top as a feature.
So the plaster is better sealed with 50/50 water as paint.
Cheers lads for the help only ever done bits of plastering but want to know the script before I get someone in.
What's people's opinions/preference with full plaster vs plasterboard (for normal areas)?
I normally board everywhere first then just plaster. Around baths and showers I use a tile board which can just be tiled directly onto and also provides a waterproof seal.
If your boarding straight onto brick , how can you guarantee a flush and level finish if the brick itself is not perfectly uniform across the wall span? Plastering would allow for any deviations to be taken into account and then altered whilst on the job no?
