R
ryan24
Hi. anyone got the best idea what cable i should run to my shed which will be approx 40m cable run. only going to be 1 double socket and a light. but also around 12 garden lights. i was thinking 4mm 3 core swa to the socket and then 5a spur for the lighting. all on a 16amp mcb? any thoughts? cheers
1) Check out the Similar Threads section at the bottom of this page.
2) Describe all the relevant parts of the proposed supply from incomming supply head, to the size of the loads (incl lighting) and earthing arrangements.
3) Show us your cable sizing calcs so far.
4) Tell us whether you're a householder / trainee / fully qualified electrician.
