B
BigSi
Installed a few 3-phase distribution boards over the past few weeks, by removing the bottom panel and bolting to trunking with a paxolin insulator between. Whilst cutting the paxolin to shape, it got me thinking. Does anybody actually manufacture a pre-cut paxolin rectangular insulator? :uhoh2:
Not seen any pre cut ones before, fairly recently used couple of hager DB's that had a gland plate with a grommet strip like trim around the cable entry so paxolin wasn't needed.
Would they manufacture pre cut pieces when most boards are different?
Yeah you can get pre made paxolin's. had a load left over from a job but the were the wrong size for the different brand of board we were using on the new job.
cant remember who made them though
I always treat them like wood when slotting, drill 25mm holes with a flat bit, then join the holes with a jigsaw blade designed for wood. If you use metal blades or a holesaw, they'll heat up, expand, start smoking, go blunt and generally annoy you. That's just my experience, might not be the same for all!
