So why does linearity go to pot at 30m?
(For all combinations of csa)
Because it's not a linear scale - the first 30m's are in 5m intervals, thereafter in 10's ('cos that's kinda how the real world works)
Hmmm...that's a change of scale at some point along the axis, arguably bad practice, misleading at best!
If you do change scale, there should be clear indication at the occurrence on the graph itself, not just the values on the axis.
not too hard to spot by ther absense of 5's after 30m though, is it.
Have you never looked at the time/current graphs in the BGB, then? They do exactly the same. There is a proper term for it but I can't currently remember what it is!
nice graph. i use this. posted ages ago on this very forum.
useful information for form filling.
That's a useful couple of pages, Tel. Cheers.
It's a logarithmic scale.... allows them to fit much higher values without having a riduculously large graph.
As Croney correctly points out, they are non linear scaled graphs.
On a linear scale, your BGB would probably have to be 2 or 3 miles long.
Re Your R v L graph: that x axis scaling would be shot down in flames in the real world!
Just reading that makes you look almost like you're intelligent. ;)
This IS the real world...........[waits with fire extinguisher in hand].
Seriously though, I'm not sure quite why you think this is a big deal? It's just giving slightly better resolution at more common domestic lengths - 1 to 30m. I guess if I made it go 1,2,3,4,5,10,15,20,25,30,40,50,100,150 you'd just panic completely?? ;)
