Recommend me .....
G
Guest55
a 250 amp panel board of as small and compact size as possible , needs only to be 6 x 3pole ways but to take 120mm tails / swa main feed.
used mem previously , which are of good build but at over 800mm wide , cabinet door opening area is too big for the pipe infested basement its going in - need something narrower
any ideas folks ?
Square D I-Line?
As far as I know, they are the only slim line panel boards readily available. Many of the other larger manufacturers are double sided, where I-Line panels are one sided.
Obviously, they will be taller though.
