T
tom79bmth
Hi All
Is there a regulation stating a distance for how far a mains water feed turn off is to a consumer unit think 300 mm not sure if its a reg or recommendation
Also in a toilet just a toilet not containing a bath or shower is there regulation on how far the light switch is from the hand basin ?
Not in BS7671 that I can think of, or any reason for there to be. neither is really a dangerous situation. Fully clothed in generally dry conditions like these, there isn't a need for special regulations.
There are no zones associated with hand basins in the UK. As for the distance from a mains stop cock to the CU, if its an existing install leave as is, if its a new/refurb then the greater the distance the better.
I think the electricians guide to the building regulations gives a separation of cables from gas and water services of 50mm and from a CU to gas meter of 150mm but no value from a water supply tap.
As above with the absence of zones for a toilet.
Ah good I was right lol
I had my yearly niceic inspection yesterday he pulled me on those two things, I said there was no regulation on them. I said it wasn't ideal but I didn't have much choice and is comply's with regulations.
Thanks for clearing that up for me
As Richard says, it is in the Electricians Guide to the building regs, it isn't specified in the wiring regs. As the building regs are Statutory, and the wiring regs aren't then i would assume that all new builds or new CU installs would have to comply with the 150mm, but i may be wrong. A classic case of common sense needs to prevail, and i wouldn't think anyone with half an idea would site a CU next to stopcock. But what is there already is there, and there aint a lot we can do about it.
Cheers…………….Howard
