J
jagdeepb
Guys , need some help.
Have a customer who has lost all lighting due a blown bulb. Have checked all connections and fuses but nothing seems out of place.
Need some help.
Jag
I got called out once when a client told me exactly the same thing. On removing the rewireable fuse it appeared in tact but a continuity test proved otherwise. Sure enough the fuse wire had blown but in the concealed part of the fuse.
Out of interest, what tests have you done? Just visual by the sounds of it? This work requires approved testing equipment which will quickly and easily indicate where the fault is:thumbsup
