Hi guys.
I'm trying to proper size a run capacitor for a tbr4a031cdm motor. It's mounted in a closed enclosure in a small reverse cycle ducted system (used for heating and cooling). The specs are: single-phase, 240v, 315w, 2.6 FLA.
the manufacturer recomends a 4 uF /440. I ran one for a year and a half and today I found it all melted and almost disintegrated. was it just a bad one?
as a point of discussion, chat gpt thinks that I should run a 35 uF
Thank you.
Double Shaft Fan Motor 315W 4P 240V PSC FR48 3 speed vented, resilient cradle
Techtop Double Shaft Fan Motor Product Code: TKR4A031CDM Replaces Below Motors: Fasco 8061S109-01 / 8061S109-04 / 8061S109-08 / 808555NVA-A16 CMG CT85-55031V-C01 / CT85-55031V-C02 Royce Cross RCT85-3154DS-ODP-C02 Kulthorn HF2J4702K Download PDF Drawing
www.electricmotor.com.au
Thank you.
