Hi guys.
I'm trying to proper size a run capacitor for a tbr4a031cdm motor. It's mounted in a closed enclosure in a small reverse cycle ducted system (used for heating and cooling). The specs are: single-phase, 240v, 315w, 2.6 FLA.
the manufacturer recomends a 4 uF /440. I ran one for a year and a half and today I found it all melted and almost disintegrated. was it just a bad one?
as a point of discussion, chat gpt thinks that I should run a 35 uF
Thank you.
I think I'd trust the manufacturer's data somewhat more than chat gpt, going by my experiences of technical stuff from AI so far.
Did you use a capacitor rated for continuous use, rather than intermittent duty?
Absolutely. And chose one that was rated for higher temps (85deg) because I thought it would help. That’s why I’m confused seeing it fail only after a year and a half… also confused to see such a big difference between what’s calculated using various formulas vs what the manufacturer is recommending.
