and then throw it straight in the nearest skip - save you the trouble of doing it two months later
the power comes in through the mini usb connector, which is stuck to the PCB with a bit of cheese. Seriously.
If you even look at the connector it will fall off just to spite you. Mine broke. Tried soldering it, but the track is literally laid on the board and is wafer thin. another guy in work walks in to see me the other day holding the same model (Navman F20) and says "can you have a look at this"
No says I, the usb connector is knackered and you cant switch it on
I would say that Tom tom are the best by far. Easy to use, very clear maps, and very acurate, almost faultless i would say. I have used a few over the years, and by far the worst was a Navman, although it was one of their first ones and they have probably improved by now.
Choosing a satnav is all very weel - but (whilst I use one) I always use Google to check out the location of all jobs before leaving. If you rely entirely on the satnav you could end up all over the place. Of satnavs I have used - TomTom is easiest to read.
ive just won a tom tom go 500 on ebay for £41 plus postage, had a peek and there going for £120 + it does need a charger and cradle but checked these and can get for £20. im pleased so far but its early days yet!!
i bought a myguide from e buyer i think it was about 70 quid
then i hacked it and it can now run tom tom, myguide and igo software i also put all the latest speed camera locations on it and it can play movies and mp3s on its own little media player
