Good morning. We've recently moved house under a housing association. Currently there's a gas hob and separate electric cooker. We want to change the hob to electric (not induction). We pulled the oven out and was greeted by a double 13a socket which is connected to the cooker switch on the wall. I've been told this is isn't suitable even if we went for an induction hob with 3 pin plug. It appears that the double socket is connected to the old cooker wiring and the fuse box has a suitable 32a breaker. Is it worth the gamble that we strip back the socket and check the wiring is suitable to fit a proper 32a oven socket? Also, could the plug be removed from the oven and have it hardwired to a 32a cooker outlet along with the electric hob? Thanks.
there are 2 issues here....
1. Can it be done... you would need to change the double socket to possibly a dual outlet cooker outlet.... or a socket, and a cooker outlet side by side... and be sure the cable from the cooker switch to here is adequate.
2. Being a housing association, are they going to allow you to do this? Some are very strict about who does what in one of their properties
