Gents
How do you all feel about running a sfs from the ring for underfloor heating at 11 amps max according to the manufacturer ? It would be a bit over the 2kw dedicated circuit recommended by bs7671 ? But as usual called in too late !!
Cheers
Haj
Is the heating mat thermostatically controlled?
There never is a thanks button showing on an iphone. No idea why.
Light loading as kitchen appliances on own ring I was more concerned about running the sfs at near max for long periods.
What's the problem with feeding 11 amps from a 13 amp fcu? Would you not run anything higher than 10 amps through a 13 amp 3-pin mains plug then? Daz
Good point Daz but wanted to be sure about running near to max for long periods but the stat wiil keep it right. My mind recalls the test in connections magazine about running on max for long periods so just made me think to check with the years of experience you all have.
Cheers
