R
Robo
A guy wants me to get him a power supply into his shed. Shed will have relativly small load. A light and a socket inside. Does this plan of attack i have sound ok. Have a 13a fcu spurred off down stairs ring (rcd protected ring). Back entry out of fcu to a galv end box. Use 4mm 3 core SWA burried under walkway (about 5m run) into shed and connect into another fcu 5 amp for the light and connect socket to supply side of fcu. This is by far the cheapest option to putting in a new circuit and board etc. Thanks Robo
but would the connections then be waterproofed? It's ok waterproofing the entry to the building but what about the connections?
I like the idea lot but would probably still fit a waterproof enclosure, don't trust my resining skills
