T
thekingiam
a plasterer freind rang me up yesterday with a problem he had moving some light switches in the hall and front room,aparently when turning upstairs landing light switch off it was turning room light off as well.
anyway turned up found brand new cu turned all mcbs rcd's and main switch off,opened light switch downstairs all red singles got voltage tester out checked if dead ok dead took out all cables from switch arghhhhhhhhh! nice jaw tensing shock.
checked cu all off plaster said there is another switch under stairs checked found mains rcd used as an isolator switched off and everything fine fixed problem with lights and left.
plasterer is saying he didn't fit cu and i didn't want to investigate further as god knows what i would find, today i was just thinking as i have just fixed lighting problem have i any legal requirement to check other works done.
all i did was put the correct cables back into switches, didn't charge anything to anyone.
legaly should i of supplied minor works cert?
im a bit confused by your post, you say you had turned all mcb rcd and main switch off,, but it was still live?
Legally, no. To cover ones backside in this instance I would say yes.
I'm a bit concerned by the fact you said you isolated the whole db and yet there were still live cables present, what was the set up exactly???
What is your registered charity number?
I have loads of work you could do for free.
You must charge even if it is small, your van does not run off air!
I am even more concerned that the switch wires were tested for dead and were still live before delving in!
i have to admit as i had a bit of a hangover and new i wasn't going to charge him i may of rushed in my safe isolation procedure. i saw a cu and turned off without checking where it was being supplied from and what it was supplying, thinking about it today i suspect there was another cu in pantry covered with so much junk i could not see it. as for the switch wires again probably rushing and as all singles in red and about 8 of them i may have been checking between the wrong circuits, if that makes sense!
the downstairs light switch had seperate switch for downstairs porch,2 way for upstairs landing and a feed connected from here to switch in front room for room light.
as for charging the plasterer is a freind of the family,my girlfreind owns a large 4 story house with two flats and he is always over here working on our house for mates rates or under.
i know the job he has on at the moment he has gone under budget as another freind of his took the mickey and messed up a load of stuff.
also to be honest it took me that long to solve a relatively easy job i would of been embaresed to charge him.
