Z
Zebra Stripe
And so it begins.....
Got a call from a landlord to have a look at tenants storage heaters "cos they're not working?!"
On arrival tenant says "the red light doesn't come on when we switch the wall switch on (neon on FCU), and there's no heat coming out (warmth for non physicists)"
I said "Cor blimey guvnor, do you know how these things (storage heaters) work, you need to leave them switched on cos they charge up over night. Cos you've switched em off fella, they're not storing up and that's why you've got no heat, me little cocker sparrow" - I said all this in a really bad cockney accent, a bit like that guy in Mary Poppins, why? cos it just sounds more realistic that way.
Anyway, I tried to drag out the coffee, and mundane small talk for about 4 hours, only kidding, was more like an hour ish, and was wondering what I should charge. I'm forever doing free bees and favors, so thought I should be more business like you know, so - £40 for call out, £10 for consultancy fees on storage heaters, and perhaps another £10 for me wicked banter and cockney impression. Does that sound steep?
Nah that sounds pretty fair, but considering you're a cockney in the south-pole i can't say business is going to be rife anyway.
I hope that is you in your working gear in your Display Picture haha (minus the gun). That'd be worth a tenner tip.
Hey, I was just putting the cockney accent on to add a bit of spice. If I looked like that I'd probably be on the game or maybe even a nun, who knows, but £60 sounds far, it is a landlord and down sarf.
£40, a bowl of jellied eels, and a grope of the maid.
Skip the jellied eels, unfortunately no maid, although I could hear movement in the cupboard!
Anyways, seriously is this domestic stuff always like this?? I seem to be spending alot of time switching things on for people, hey is that why it only takes 5 weeks to train to be a domestic electrician?
Im waiting for "TV dont work" cos the fat B has lost the remote and needs me to come over and change the channel
Can be like that.
I replaced a fuse in a spur the other week and made an outside light work that hadn't for 3 years. Woman thought I was a magician.
Lamps blow and RCDs need resetting, light switches get swapped and 2 way won't work, blown lamps and people never think to check, people unable to replace fuse wire, etc.
I had the E7 thing myself not long back. Guy had replaced his storage heater and spur but it wasn't working. He had left the main switch turned off on the E7 board.
I asked why he had replaced the heater and he showed me the burnt out fused spur unit, fuse still wedged in. He had assumed the heater was faulty so bought another one to the tune of over £400. I asked if it was the same as the last one. Turned out it was, they were both 3.4kW models. Probably nothing wrong with the one he chucked out.
Got a call this afternoon, "all the power's gone off, can you come round urgently?" About 45 mins later and I'm there, credit to the lady or not she had all the 3036's out and was checking if any had blown... none had.
Asked to see where the DB was, she pointed to the cellar..... went down and first thing i noticed no display on the energy meter. Went back out to the street as had seen workmen working a couple of streets down, walked over to them and they confirmed 4 lines had been cut and were in the process of fixing, 2 hours later all power was restored. Couldnt really charge her as was only 10 mins from home but as she's a hairdresser she's promised me a free haircut.....:gorgeous:
Alot of the time mate.
Today I changed a 5' fluorescent for an old boy, had to charge him the minimum call out though, then went and changed a 2D lamp in a toilet for someone else, and then changed a double socket and a 2 gang dimmer switch for a third customer. That took me up to 11am and then I could start some 'real' work.
I used to feel guilty for these little jobs, but then I realised that I had to make a living and other people would charge more. I will still do 'freebies' if its on route to another job and takes less the 10 minutes (ie. RCD tripped when lamp blows)
A recent one for me was heater not working in bathroom in sheltered accommodation. It was the switch had been accidentally switched off just outside the bathroom door. The switch had no label so I labeled it in large print font and all the other fused spurs in the kitchen as well, and made a small charge.
I have just quoted over the phone tonight £50 to change lamps in a barn conversion plus £2.50 per lamp. Simple job but they don't have an extension ladder. So it is my time and tools.
Although I might only be in the house 30 minutes it's 2 miles there plus time to get the ladder out my garage etc.
I had a commercial job few months ago, local electrician had installed some sockets in their comms room, that apparently had never worked.
Got to the job, strange place, lots of three phase mains intakes spread around the building. Anyway, found the problem, the dosey prats had supplied the sockets from a storage heater DB, labeled storage heaters off peak supply, quite obviously connected to a contactor and time clock.
Perhaps they were working out of hours, at a time when the board was live, and probably couldn't read, although if that was the case how did they pass the C&G 2382?
