Hi everyone
Iam installing a 25A supply to a machine from a canalis busbar system the machine is Tpn and earth. I have a 5 way tapoff unit . Should I be using a four pole breaker so I issolate the neutral or should a 3pole breaker be fine. The busbar system is a ska 800amp system which governs more equipment around the building. Iam thinking of unbalanced loads and current on the neutral
Cheers Cosmicsun
Cheers Cosmicsun
