W
wade88
Getting this Arc welding business down to a reasonable art now...minus the splatter...
I don't know: the line wobbles a bit and it goes a bit deep on the left!
Ahh shut up, Richard, you are just jealous because it is far better than my welding!
Looks very tidy to me.
Have you considered using a solution of detergent mixed with water sprayed onto the work to reduce spatter?
You can purchase anti-spatter spray, but it is just diluted washing up liquid.
When you say it is arc welding, is it Man-Mag, Mig or Tig?
With Mig, a change in the shielding gas can reduce the spatter.
wade88
done alot of welding in the past and I would be 'appy with that.
Deffo arc?
Ever done and aluminium? Never did that, always fancied a go and stainless. Got MIG down to a tee though. Best one was repairing an "unrepairable" expansion chamber for a mates 2 stroke bike. He nearly wept when I handed it back to him
It’ll do to hold tray brackets up. Now try welding the tray it’s self. MIG or gas are the tools for that, (with good fume extraction).Take you’re test piece and cut across the weld, you’ll find the penetration depth and slag inclusion. If you then polish the cut (and I mean polish) you can use crack detector on it. To do my test pieces I had to surface grind and lap them before they went for evaluation, the welders on our course weren’t happy that an electrician got coded status. The company I worked for was closed shop, so I never got the chance to renew my coding after I finished collage. On the works if I were to be seen welding there would have been a near riot. One man, one trade, it was ridiculous, changing a motor needed 4 trades.The more you practice with the welding the better it will get. And it’s FUN! By the way that’s a bloody good consistent run, the wobble will go with practice. Just one word of warning and you probably know this already, ventilation is crucial with unistrut and tray, keep yourself healthy.
No this was a stick weld, im currently making a fire pit grill stand for the old man for christmas. Only really been stick welding for the time being, i have just dragged out and cleaned up two MIG welders i found at work here and started to have a go at them but need to do more reading to make sure i get the right settings down on the machine for the right steel thickeness etc as my welds have been coming out with barely any penetration and very unconsistent.
I can replicate that sort of weld (which im fully aware in the grand scheme of things is probably pants but its the best level im at for now) on most metal thickness and most angles, apart from over head i end up with more on my boots then i do on the join...doh!
Its great though i love welding, i managed to make a crossbow a few months ago...not massively practical but should a zombie apocolypse ever come our way im pretty much sweet. No Spartykus ive only welded mild steel as of yet, but im dead keen to learn to weld stainless. Problem is, its sort of taking over my life a bit, all i want to do is weld things together...would like to get my hands on a TIG too, the neatness of those welds is just unreal.
Spin ive seen a sort of acid solution that eats away at the weld and exposes any spongey bits and areas of little or no penetration showing you where your weld is weak but i havent found anywhere that sells it yet? But as far as reducing the splatter i tihnk i just had the amerage up a bit too high to be honest on that particular one. Right well im on to my second coffee of the morning already and im getting some sideways glances in the office, i think they all reckon i spend too much time faffing around on here instead of working....philistines. Im going to go weld something pretty. Pictures to follow.
I made this frame up at the start of this year to put all my steel on, this was my first project i guess, took me about 3 hours start to finish. The cross beam does match up though before anyone says anything!! i didnt get the measurements that wrong! lol, i just took the photo before i had finished it.
I like welding fresh metal like what you have there, but when doing welding on my old baywindow camper is a totally different game, when you cant find a decent area to weld to, then the paint or sealant catches fire in the cavity or otherside.
Absolute nightmare. Speaking of setting things on fire. As Tony rightly pointed out, safety first...however, i went into work a few weeks ago in trainers, left my stealies at home due to severe football blisters and didnt want to further anger them. But then ended up welding some oil pans and drip trays, totally forgetting that i was wearing hugely inapropriate footwear, and then the hard and fast realisation that my foot was on fire was quickly upon me as i looked down to smell burning foot and a smoking trainer as two lumps of molten metal found their way through my shoe, sock, then half way through the top of my foot...i couldnt get my shoes off in time due to the laces being done up, torch in one hand, piece of metal in the other, both of which found themselves half way across the shop floor, but the damage was already done. BBQ'd foot. 4 days later a lump of metal worked its way out the crater...lesson well and truly learnt
