B
bigd
No prizes (sorry). On the plus side the customer said the previous electrician was very cheap!!
I was very lucky when I removed the busbar cover thinking the main switch was off!! I should have taken a few moments to admire the previous electricians handwork-lesson learnt I think
obviously done by someone without the slightest clue. plumber?
I'm speechless. The old CU installation must have been safer than the 'upgrade'. I'd just quote him an hourly rate and rip it all out and reinstall from scratch along with some testing.
I can see the problem - one of the breakers has tripped. You just need to flick that back on, problem solved. Easy!
Seriously though, I've seen loads of old boards (or rather 'consumer units') in similar states. It almost seems like making the inside of a CU neat and tidy is some new-fangled idea.
nevermind the wiring !! look at the rcd module , its wider than a bus !!
:-D
About as big your arse!
Spanish flat, about the size of an average house over here, 20 or 30 DP breakers in board.
Think I'm getting some ayjayness there!!! haha
