Discuss star ? delta? in the UK Electrical Forum area at ElectriciansForums.net
a pic of the rating plate would have made life easier. but if we wanted an easy life, we;d not be electricians, would we?
i know. sometimes i don't know why i bother. :6:
on the bright side , tony usually does. he's often pulled me up on motor theory, of which he has far superior knowledge.
Like usual the Tony the OP has provided no info asked 2 basic questions and slipped away leaving the in-house banter .... and for that reason Im out... well off to pub anyway :grin:
order me a large one. i'll pay the round on tuesday. :smilielol5::smilielol5::smilielol5:
I’ll stick to Derbyshire’s version of scrumpy, Scrimpy. I’d put it up against that west country stuff any day.
Scrimpy
Bramley Street Cider Co, Summercotes, Derbys.
Reply to star ? delta? in the UK Electrical Forum area at ElectriciansForums.net
Hi Changing a 3 phase star delta motor and replacing with a dol 3 phase motor. Would i be right in thinking I can remove 3 of the 6 cables at...
What tests and certification do you do for motors supplied via a motor control panel, DoL, soft starts, VSD, star delta, etc?
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
Hi. I need to alter the configuration of this motor wiring from star to delta so that I can use a VFD to control it (hopefully). If I remove the...
