T
TPES
Just checking that I am required to install a 300ma RCD supplying the structure as per 740.410.3 (it cost £8k to put up so is not exactly temporary).. Used to store vehicles.
It does not sound like it is at "fairgrounds, amusement parks, circuses or similar places" so 740 would not apply.
Is the supply intended to be disconnected and reconnected frequently?
Is it a temporary supply or a permanent supply?
If you have a permanent supply to a fixed structure then the general rules apply.
