B
BertUK
hi guys just want some of your thoughts on the best way to do this. walk in sunbed with 50 tubes at 100 w.....fan in bottom at 1kw and a downlight. its already fed from a dual rcd board on a 32 amp mcb,6mm cable and a cooker switch. the sunbed needs moving about 12 mtrs away from the board so my idea is 40 amp mcb...10 mm t+e and a 63 amp fused isolator on the wall near the sunbed.any suggestions welcome.
i cant see a need to upgrade cable size :S or breaker
why do you want a fused isolator when you have a 40A MCB as OCPD?
I just thought because of the distance its going to upgrade cable size....and the isolator is just for maintainence purposes
50x 100 = 5000watts 21.5amps
1kw fan 4 amps
light .2 of a amp
not even pulling a load a 7.5kw shower would
