Bit of a strange one .
Was called out to a loss of supply in a house . There appeared to be no supply as the meter wasn’t lit up but once I turned the main switch off it came back on .
I switched all the individual breaker off and turned the main switch on , the meter then stayed on , but when I turned any mcb on, the nie meter cut power after a few seconds . I noticed when I turned the lighting circuit on , the led lights flickered on and off for a few seconds before the nie meter switched itself off .
There hasn’t been any work done in the house and this just happened randomly .
The supply is coming in high level and I traced it and can see no signs of damage . I also tested it for the few seconds is stayed on and there appeared to be 110v across neutral and earth .. is it possible a faulty meter is causing this or am I hunting for a short in the cable somewhere?
