Discuss Terminal Identification in the Electrical Forum area at ElectriciansForums.net
I've found out what type they are, but to get a larger size cable entry, the modules are larger. Not sure I want to do that, so I could add a couple more and redistribute the cables: one set have 5 x 1.5mm flex in them! (not shown in these photos). Then I run out of room on the rail, so do they have to have the end backets?
You can get different types that are same physical footprint, have you got the dimensions you want to be close to? :)
Not the best of practices but If the earth terminals clamp to the rail using a centre screw then they can act as end stops, from memory some phoenix et's grip the rail with a spring type action so will restrict movement.
Why is life so complicated! I've found the items I want (see below), but now I can't find anywhere that will sell them singly.
Any suggestions?
Phoenix Contact
1 x 3003347 UK 2,5 N
1 x 3003350 UK 2,5 N BU
2 x 0441119 USLKG 2,5 N
Any suggestions?
Phoenix Contact
I have made a phone call waiting on result ill let you know when i do :)
Reply to Terminal Identification in the Electrical Forum area at ElectriciansForums.net
