Discuss Terminating 35mm in the Industrial Electricians' Talk area at ElectriciansForums.net
Most would accept 35mm with no problem. If you’re worried about it get some reducer pins just in case.
Is it domestic or commercial?
As above, I think all of the switches and incomer RCD I have looked at take something like 50mm. BUT wrangling that in to place can be a challenge!
I'm guessing this is SWA and not separate double-sheathed tails?
Suitable SWA gland is no problem, but I don't know if any of the tails style of glands for domestic boards would be happy with 35mm, even assuming someone makes 6181Y in that size.
Reply to Terminating 35mm in the Industrial Electricians' Talk area at ElectriciansForums.net
Has anyone fitted an SPD to a schneider standalone AFDD DB. Isobar P B Standalone Active distribution board, Acti9, 24 AFDD ways This board only...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
Hi I'm installing two new sub-mains. I need to parallel some of the supply cables. It's the main incomer in 5 x 25mm, with 5 x outgoing 25mm...
Hello, My house has 25mm back boxes throughout, but I’ve noticed the previous owner has installed sockets and switches that seem to...
