J
jeffelectric
Earth joined to neutral at head and wire to sheaf on incoming ?
well then its either a DNO upgrade.....due to deteriation of the TN-S arrangements....I believe the OP is saying the incoming has both an earth on the sheath or whatever a sheaf is... as well as an earth into the cutout N/E connection...... Its probably been converted tns to tncs so your answer is tncs....usually a pme sticker has been attached. The armour still requires earthing whichever set up it is but this isn't down to our responsibility.
