Dizzy_Maskell
Looking at getting some of these for my house as look good and so far I have never found anything that will secure something to my walls cheap, poorly built new house hollow walls bout 1mm thick every where.
Just wanted to know if any one has used them before, look a bit different with the click out feature,
Cheers guys
link for us to see?
Sorry chaps bad signal all day,
Here is a link much appreciated
http://www.toggler-uk.com/
Various anchors but was looking at the "snap Skru"
Any advice be great, not seen these myself so if any if you have tried them let me know.
I haven't used them but they looks as if they would work OK.
I would not be putting my 35kg plasma TV on the wall with them or anything valuable near the weight limit, plasterboard has limited strength itself.
If you were needing something solid, assuming you have double skin, double layer plasterboard "walls", I would be trying to get a support fixed inside the wall to supply the strength.
Any of these type screw-in fixings (I use the Spitt ones) are only ever as strong as the plaster that they're screwed into, and it's not unknown to put one in to only then have a big hole to patch up afterwards. If you've anything with any weight or leverage involved, then run a plate/batten/board/etc back to span between the joists and come off that, instead.
Yeah not for anything to heavy just had issues with shelves in past had to use batons and double up on everything it is a nightmare but I'll give these a go and let people know my findings
I've used the metal type - same style, self-drilling etc. Seem very good. A doddle to install. Never seen this type with the 'audible click' thing though. Daz
Took the hit chaps and ordered a box I'll be going crazy at the weekend with stuff so let u know how get on.
Thinking new company as my order was 00000000000015
Which could be if some concern
