- Reaction score
- 0
Callout to a house split into 2 flats with loss of power to 1st floor flat. Fault was virgin installer drilled through ring downstairs and popped fuse. Their facilities management called out a spark from 2 hrs away who attended and made safe the damage and replaced fuse wire in basement db feeding sockets. Prior to that installer monkey was prodding the old Wylex 3036 board in ground floor hallway and switched off main switch killing power to 1st floor. This wasn't seen as no one was in upstairs til late. I attended site to find this.
Next to switched off Wylex. Can't be live I thought but yes all working fused lives and neutrals on lighting circuit with a floating earth to slip Conduits below.
Was twitching a bit as didn't fancy touching that live then noticed Wylex main switch off lol
What age would that be im thinking 20's ish ? Did mention that this is the only place I've ever seen one haha
Did recommend a full test poss Rewire and picked up a restraunt fit out that the house owner is planning new year.
