Discuss tyre pressures in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
haj
Anyone have a manual foraVauxhall combo 1.3cdti ? Would like to know what the tyres should be at checked some sites and they say 35psi but that seems a bit low to me.
Regards
Haj
there should be a sticker as you open one of the doors to tell you that. failing that, stick 32 in the front, and 35 at the rear. it'll be fine. trust me :shades_smile:
Regards
Haj
if 35 psi seems a bit low to you, try 80 psi. I heard you get really good mpg with the only negatives being very little grip on corners (a small trade off). Let me know how you get on.
- - - Updated - - -
Regards
Haj
35 sounds about right for standard car tires.
My car a c1 is pumped to 34psi
Then again its only 800kg.
A transit has recomended psi of around 60
Don't go over the max embossed (raised) on the side wall of the tire
what's wrong with a swift kick? anyway, if you come over to scouseland, you won't worry about tyre pressures, you'll worry where the bloody wheels have gone.
Reply to tyre pressures in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
  • Locked
Hi, I realise this is an electrical forum and not plumbing, but was wondering if somebody could help. My heating is not working and the heating...
4K
Hi there, I am looking at specifying a Triac dimmer switch after a PIR and manual override to control several lights, i dont see an issue why...
Hi, I have a princess 1500w smart glass panel heater which only chucks out half the heat it should. I've checked the thermal fuse with a...
Now Ive done Periodic Inspection and Initial Virification Qualifications with LCL/EAL (so non C&G 2394/95) # strange part building Modules , this...
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
