Discuss Ungrounded receptacles in the USA area at ElectriciansForums.net
Megawatt
Staff member
Supporter
I have a customer that has no equipment grounds. The code enforcement will not let you pull a single ground. Any tips on resolving this issue
Mate this is a UK based forum, therefore you won’t get much response regarding US code.
Haven't a scoobys buddy but loving your Trump fella, worlds number 1 troll, make sure he gets 4 more years.
MAGA....
The ---
MAGA....
The answer is install GFCI breakers On all the single pole breakers. I just wanted to see if someone would thought of that. Sad
If the receptacles are not grounded and your Codes do not allow a separate ground around them then surely the only option is to rewire.
The ---
MAGA....
The answer is install GFCI breakers On all the single pole breakers. I just wanted to see if someone would thought of that.[/QUOTE
thats what I thought until I spoke to the inspector and GFCI BREAKERS was his reply. I’m in America and this site is UK so I’m positive there are huge differences in what we do compared to UK
So if you use GFI outlets then you don't need to provide a ground at the receptacle?
DPG you have 2 choices 1-GFCI receptacles or 2- GFCI breakers on all single pole breakers
Your OP seemed to be saying that you could get away without a ground wire if you had GFI receptacles. Have I missed the point?
I turned the down the job but followed up on it and I was told that they went with GFCI breakers and that satisfied the code enforcement.
I'd reckon Dan is trying to push this beyond a uk forum. The .net change from .co.uk, and the little location flags...change is in the air.
I was open about it when I did it lol. I said that's why I'm doing it in multiple threads and in my own and in notices.
I wasn't trying to trick you lol
[automerge]1566769914[/automerge]
Looks like you were right we have all sorts of forums from other countries now
As above. ;)
Reply to Ungrounded receptacles in the USA area at ElectriciansForums.net
I am a complete novice when it comes to electrics but I have recently bought a grounding mat and so I've been doing some measurements and I'm...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
