O
Octopus
working on a bungalow to chalet conversion and the customer has just decided that all the upstairs rooms will have full height vaulted ceilings ....... it’s all latest spec insulation so how best to run the feed and loops around between the switches ?
So no lofts ......
Where are safe zones apart from inline with the switches and within 150 mm of the tops of the walls .....
A PITA...
Might be easier to run the mains to your switches, (from the floor) then you’ll just have the the one cable up to each light (or two at most if more lights controlled from one switch)
Also I would imagine any surface wiring/containment would have to have metal retainers in case of fire.
Varnished or painted conduits, timber preferably, between light fittings, single feed, use quinetic switches to avoid switch drops?
A pic would be helpful.
metal retainers:
I tend to loop at switches these days ..... makes fitting pesky customer sourced lights a bit easier.....
Just finished a very large house with 15 vaulted ceilings, added a twin LED tape at the spring point to uplight and worked fantastic. All wiring in underfloor screed floor tray and conduit up to each socket, wired in 4mm singles. Where we needed large pendant fitting some over 120kg they were installed with metal plate and 4 x epoxy glued s/s studs direct into the ceiling and then tested for 3 weeks in accordance with the structural engineers instructions, had to be creative with the wiring. Some lighter light fittings we were able to use carabiners onto a ceiling ring. All controlled by Control4. At the end a very happy client.
Vaulted ceilings ..... late decision .... grrrrrr
Octopus,
Flanders,
