I have an Aldi long reach hedgetrimmer supplied with a 20 V Active Energy Ferrex r/c battery. This combination is light to handle but woefully underpowered and keeps jamming. There is on sale an equivalent 40 V Ferrex battery. Confusing situation because some batteries and chargers seem to be dual voltage. Question is, if I fit the 40 V battery is there a good chance that it will blow (fry) my electrics? And/or does the mAh rating come into the equation? Tks.
If you fit a 40V battery to a 20V tool, you will likely destroy one or both, except they ought to have different connections to prevent this!
Lithium batteries and the like store a lot of energy, are potentially dangerous.
They can have safety measures incorporated in them such as temperature sensing and sometimes digital communication between battery and tool. Different manufacturers can adopt different approaches, so circuits can vary, for which reason different brands are typically not interchangeable.
I urge you not to experiment by trying "incorrect" batteries in a product!
The mAh rating indicates the amount of charge the battery can store and deliver, ie typically related to how long it will give the necessary voltage before it needs recharging.
If you need more 'oomph' to do the job - drilling or cutting - you really need all of:
A more powerful motor in the tool, which may mean higher voltage
The higher voltage battery to operate the more powerful tool, and
The higher mAh rating for the battery that comes with that.
Thanks let me ponder what you have said. It would seem that there isn't a way of getting more oomph from the existing tool / hedge trimmer, under-powered as it is. It seems that it is all a matter of the voltage - and I can't experiment without risking overloading the tool. What I find confusing is where in the description of the replacement batter(ies) it implies dual 20 / 40 V.
If the manufacturer is offering a 40V battery for your specific tool as a plug in alternative to the 20V, that's fine.
Is there both a 20V version, and a separate 40V version, of the hedge trimmer, that the 40V battery is for?
There could be dual voltage batteries, designed for different voltage tools - that's a separate topic.
I wanted to emphasise that, unless explicitly stated in the instructions for the tool, it's not OK to just double the voltage of the battery. It could be dangerous.
I would be quite surprised if it would physically fit though!
Just to pick up on this point, it's really a matter of current.
Depending on the design of the motor, its power is related to the strength of permanent magnets designed into the motor, the winding(s) - (thickness of wire and number of turns etc), how any electronics driving it have been designed etc, and ultimately the amount of current you can put through the system before it starts overheating and destroying itself.
The only way you have to increase motor power "from the outside" is to increase the voltage, which seems what you are motivated to do. But it risks burning out the motor, and anything else in the tool that uses that voltage.
If the motor were to short circuit, the amount of energy in the lithium battery, liberated all at once, can cause a fire or explosion. That's my main concern - your safety!
If you want a more powerful hedge cutter, you need one with a more powerful motor. 🤪
Edit - just been looking at the Ferrex 20/40V battery. You can fit it to your hedge trimmer, but the trimmer will still run from the 20V connection, with the same result as at present. The battery may last a bit longer than the ordinary 20V one though.
Durham UK
United Kingdom
Voltage / power query
UK
Telegram Sam,
Avo Mk8,
