I'm sorry but a bit confused about exactly what was installed.
Are the click twin 13A sockets equipped with USB C PD sockets, or USB A and are 5V? What model are they?
And are the click sockets in the kitchen
exactly the same model/part number as the ones in the rest of the house? i imagine they are supposed to be, but is there an odd one (or two) out?
I could understand the scenario where her plug-in charger will charge her phone quicker than a Click USB socket does, but that depends on the age of the phone and what you've installed, and it's not what I understand she's claiming.
Also:
As per Littlespark, there are many parameters affecting charging time of a phone, to do with the age and state of the phone battery, ambient temperature, whether using original or generic charger, whether the supply/phone pair is operating in PD mode properly. Also the strength of wifi and 4G signals being good or poor could affect apps running in the background, and possibly thus charging time. If phone apps were for some reason 'busier' in the kitchen, it might be the cause of longer charging time for both mains and USB charging?
The power needed for phone charging is so tiny I can't imagine the kitchen circuit has any sort of fault. Maybe there's some bizarre conducted interference on that one circuit (unlikely), or there's something about rf interference or signal strength in the kitchen that's different from the rest of the house?
Sorry I'm not trying to be a right know-it-all because I'm really not, but there are so many variables.
You could buy the monitor gadget mentioned by James in post#2 and show what's going on - I'm going to get one
PS: The PD chargers negotiate with the phone/device and select a suitable voltage from 5V, 9V, 15V, or 20V, so it's not about the maximum current from a 5V supply, it's about what range of PD is operating and the compatibility of supply with the device. The little test tool in post2 would show what volts and current have been negotiated.
I suspect the charging time experiment may not have been conducted under sufficiently controlled conditions (logging start and finish battery levels, app activity, signal strength for wifi and 4/5G etc. etc) There may not actually be such a problem
