Your question asked: Having passed (presumably) the C&G 2393 examination what can I do?
Based on that my answer stands. Unfortunately that examination has little employment potential.
If you have experience in first fixing and you understand and can apply the basic circuit information in the OSG, then you may be able to correctly select a cable for a standard domestic circuit and correctly install it or, if you were given a particular cable and told to run it then you should be able to do that.
However this is above the level you proposed in the question.
Having a qualification for first fix would mean that you had correctly selected the appropriate cable and an appropriate installation method taking account of the capability of the selected cable for the intended final use and the intended methods of protection.
Testing of an initial installation is covered in theory by the 2394 C&G examination.
Testing of an existing installation by the 2395.
Employers are looking for experience primarily and prefer it to be backed up by significant qualifications.
Sorry to supply bad but realistic news, if you are keen and apply yourself then there is a chance you can do well, but there are a lot more hurdles still to jump.
Good luck.
