No matter how hard I try I cannot source a simple metal box to hold a short section of DIN rail that also has a solid metal lid.
The scenario is a simple one - I need to sort out the mess left by a (now deceased) builder that fancied himself as a bit of an all round expert on just about everything in the known universe - including electrical matters.
The situation: there is a 25 mm 3-core SWA cable feeding a barn approximately 100 metres away from the incoming electricity supply in the house. Obviously he miscalculated, because what he actually needed was a cable approximately 105 metres long. So what he did was to (quite literally) nail up a bit of 50A chocky block to a rafter and extend the cable so that it would reach the consumer unit. 50A I hear you say? Surely that is not sufficient? Well, actually it is, because the circuit is fused at 40A due to considerations re the length of the run - so he did at least get something right or at least showed some understanding of the need to derate accordingly or took advice from somebody that did. Mind you, considering the nature and scale of the other problems with the electrics in this property, my money is firmly on the latter of these possibilities!
Unfortunately however, the need to joint the armour was simply ignored and filed under the "Too Difficult" category.
Anyway, I digress.
I would like to regularise this situation by getting rid of the chocky block and enclosing the necessary new connections inside a metal box with a short DIN rail loaded with MF DIN terminals
Metal because the box needs to be able to adequately support the installation of two SWA glands that in turn need to handle and support two distinctly uncooperative SWA cables. Plastic boxes simply don't have the balls for this kind of work IMO.
I don't wish to get involved with solder (which anyway would not really assist with the armour - although there are ways around this) as the necessary kit is 100 miles away in the workshop in London. Nor do I wish to get involved with crimping, although I do have the necessary tooling with me to (mostly) accomplish this albeit I would need to obtain suitable crimps. One possibility is to use an underground jointing kit but I also don't particularly want to get involved with pouring resin above head height whilst balanced precariously at the top of a set of stepladders.
So, I settled on the idea of DIN terminals within a metal box.
But do you think I can find a suitable metal box that either includes a DIN rail or at the very least has the mountings for one?
No, I cannot!
I'm sure that these used to be commonplace once upon a time, but I cannot for the life of me source one now.
Can anybody point me at a URL where I can buy such a thing nowadays please?
To be clear, this is just to joint a cable. No MCBs (or anything else) are involved hence I do not need or want a box that has a great big slot in its lid to accomodate such things.
Anyway, I digress.
No, I cannot!
