M
mascip
Hi, in a bayonet socket I have tried a 12V BA15D light bulb (LED), but it doesn't work.
Trying the light bulb with a battery, I found out that one of the two pins at the bottom is for the positive, whilst the other pin is useless, as the negative must be applied to the light bulb metal body.
The bayonet socket provides positive and negative on the two pins at the bottom, but the metal body is not connected to the negative.
So that's why this light doesn't work: the negative given by the socket is not in the same place as what the light bulb expects.
This tells me that it's not a BA15D bulb that I need.
So, which type of bayonet fitting is it, that I must get?
