A
Andrewbeechcroft
Hi, I have taken out an extractor fan from our bathroom to clean it out but didn't take note of the wiring and now I'm worried I'll wire it up wrong when I put it back. Can someone please advise me which wire goes where?!
The wires coming out of the wall are red, yellow and blue. The wires in the fan unit are brown, blue and black.
Thank you!
a picture might hrlp...
Here's a photo, cheers
As in #4 does it have an isolator and if so can you show a clear picture of the connections. ENSURE THE POWER IS OFF.
conventionally,blue to blue (middle terminal 2 in the fan). then the red an yellow would go to 1 and 3. wrong way round fan won't work. if so swap red and yellow. ensure isolation before starting as even with light switch off, there's still alive supply. isolation is by the 3 pole isolator, or if uncertain, kill the power at the CU. to be safe, turn off the main switch. (then reset all your clocks and sky boxes ?).
Conventionally yes but we cannot be 100% certain. It would help if we could see a clear picture of the isolator connections to confirm the function of the blue.
Ok, I have been told by the previous owner of our house that the yellow goes into the black, blue into blue and red into brown. However I put it all back but now it isn't working at all. Before it was working very slowly so something has changed. Any suggestions other than call out an electrician?
Yes there is an isolation switch. Its controlled by a light switch (dimmer).
So if it was running slow before what is the dimmer set at now it could be that the voltage isn't high enough to run the fan
