Discuss Wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
A
AP Electrical
Just out of intrest who use's what wire strippers? seen alsorts about but I've stuck to my old plier type wire strippers, anyone use the automatic ones and are they any good?
I use cable shears, like these:
Can't be doing with carting around a load of gimmicky tools.
They do allsorts. You can flick the handles round and use them to open boxes.
You can't use them on steel or live wires though, unless you want to break them.
Im with novus, you simply cant beat the shears. That is all you need, whether you are stripping alarm cable or cutting 25mm tails... just got to learn that no matter how many times I try they just cant cut 3.5mm screws!!!
I use good old 'side cutters' or 'snips' as I call them.
But have you seen this bad boy Draper Expert 185mm VDE 6 in 1 Plier/Side Cutter/Wire | eBay UK
It's not a great picture, but you get the idea..
I was sent a free pair by Draper to evaluate. I didn't like them and ended up giving them to an apprentice.
The draw back to the design is the position of the stripping notches at the very point I normally cut with my CK combi-cutters, if there were other advantages I could have changed my technique, but they flattered to deceive.
The angled head design didn't seem to be more comfortable in use and the cutter blades where less robust, hard or sharp compared to my trusty CK.
The wire loop capstan however is a nice touch and works well.
The bootlace ferrule crimper works on small flex sizes, but is really a gimmick because it's obviously not as good as a ratchet crimp tool. For the one off OK, any more and I was reaching for the ratchet which is faster and consistent.
The accessory screw cutters work OK, but required more leverage than my CK.
ive got a set of wire strippers which i use for panel work, as some companies (national grid and YEDL sites) ive worked for wont let you use shears on panel work.
the shears are the best, and they are just as good at small sizes as they are at bigger ones. i would never again use side cutters, and havent since college.
lenny i too have a pair of the CK strippers not a fan you have to turn them round to use as it damages the sheathing otherwise
I am not a fan at all would have preferred some cable shears or a ratchet crimper this came with CK toolkit
Did they come with a packet of sticky plasters for when you get ya hand caught in them botttom bits.
:D they should do, some nice blisters I have had of them there bottom bits :) usually followed by the cursing noise and blue coloured language afterwards :D
Reply to Wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys Can anyone recommened a decent cable stripper for flat and 3 core cables? Here's a couple ove seen online...
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
