T
tbs1983
nothing Electrical here, just wondering if anyone has a woodburner? if so are they worth having. Are you happy with yours ? Ive got gas central heating at present but have a free source of firewood, unfortunately I have no chimney in my house as its fairly new so flue route might be a problem if I bought one.
Yes, got one, yes, brilliant. Also got open fire.
blinkin brilliant in a power cut.
i know the wood burner is more efficient but still love having a stonking great fire in the midlle of the house....
Also never paid for wood in 8 years, always manage something. Its funny as a huge pile of 'tree' usually piles up at the front for processing into splittable chunks, then splitting, real proper mans work, bloke over the road can't under stand it, keeps offering his hydaulic splitter, asking about the strain on my back and shoulders.
what strain?! What gym membership!!!!!
Find your closest shop that sells them and go and talk to them. Lots of newer houses have them fitted and they "spring" stainless steel chimneys attached to the side of the house.
What is your ground floor made of? If its a suspended floor you will need to make changes so the fire sits on a solid, non combustible surface - and there are minimum sizes too.
There is a maximum rating of fire you can have fitted without involving LABC - I think its 5Kw - but don't quote me!
Hope this helps.
Hope this helps.
My lounge is suspended with a deep void underneath, I wondered why there was such a good draw on the fire so went for a crawl around, basically there is a huge steel pipe that just opens into the cavity sucking as much air as it needs.
When they fitted the woodburner, we had stripped back to some original quarry tiles from the 1800s, beautiful they were, was really looking forward to seeing the woodburner sit on them, but no, there are as Murdoch says lots of rules and the wood burner had to be a minimum height up off the main floor.
Macho man swing that axe
Yes i have a woodburner and it is the heart of my house :) there is something special about them. They can use a fair bit of wood however! I recommend getting a 'multi fuel stove' instead of a woodburner, i wish i did because it allows you to burn things such as coal, where you not 'supposed' to in a wood burner, due to the fact it has no grate and doesnt allow ash to drop off. wood/coal burn differently.
Yeah there great things, can burn anything in them.
Old house had one... Great but it's a lot of work getting enough wood and cutting etc, cleaning them is also a pain but in general they are great... My new house has had 6 chimneys stacks taken down below roof level and each room opening bricked up ( up & down ) getting prices to have some / all put back into action .. I can see some silly expensive quotes coming in
Found a lot of southern shops very expensive when looking for our woodburner, ended up buy from Machine Mart, a lot cheaper. Only thing to remember, is the solid flue pipe, ends up costing more than the burner itself.
coal/wood burning rayburn....not up & running at the mo though...
i need to get a load of class 1 flue for it....not cheap...
Thats just the ticket. Holocaust? No gas? No electricity?
No problem.
its a rayburn royale...partially dismantled at the mo...
i have removed the backboiler on it....good for 3-4 rads ....welded up a `wrapround boiler for it....good for 7-9 rads...
Although they are hundreds fitted round the country,LABC will need involving,(like that happens a lot...) the 5 Kw threshold is regarding room ventilation,not regs.Again,if they are fitted correctly,no probs (sounds like another job we know...) My folks have run a Dunsley Yorkshire multi for 2 years now,and it does upstairs rads and large horizontal indirect. Flue lining with insulation DOES work and DO pay heed to pipe sizing and falls on gravity circuits. Please do not rely on pumping to function heat loss. An awful lot of so called "installers" are,and it is bad design. Check if your area requires Defra approved appliance,then work through list of devices. The difference between £300 stoves and £1000+ is immense,and all the work above it is the same anyway,so don't skimp on investment. Obtaining and splitting your fuel DOES make you more of a man,as i am testament to...:conehead:
