Completed a rewire around 2 1/2 years ago now, customer calls and says light in hall not working
turn up and s/l from switch has worked loose, no dramas
put call out charge in, customer seems surprised and says it must be down to me as i only just rewired house
Joking, i said " i give a years warranty with my installs not a free lifetime maintenance contract"
whos right?, i maybe think i should of let it go without charge as it was a simple job
but then again it has been two and a half odd years??
No, I wouldn't charge but then I give a 3 year's warrantly on my work.
To be honest I wouldn't charge even if I had a 1 year warranty as I think a loose connection points to either a dodgy terminal or it wasn't done up properly to start with.
All assumes there are no signs of abuse or tampering of course......
Out of interest, what make of switch was it?
shouldn't go lose to the point of not working in that time, 1/4 of the periodic inspection time? Would suggest you sample other points to ensure not a wider issue. fix route cause not symptom.
I would not charge as above and also shows a good quality of after care
- - - Updated - - -
But do see where you are coming from
Yeah it's a tricky one , im all about service and aftercare and understand how important it is for customer relations and business and would normally have let it slide but he did have me over on a few extras now I think about it so I think I will still charge him
The switch was just a cheapy, it was that kind of job
I suppose if on way home or something not to bad but if monster drive and out if way need something back however for a quick fix us it worth losing possible customers though word of mouth
..... but he did have me over on a few extras now I think about it so I think I will still charge him ....
Wasnt one of those jobs where you left a few Gremlins in the system knowing you'd get a call-back and could re-coup your losses ;-)
Business head on - small job, no charge.
Normal head on - who the F does he think he is. Charge, and charge double for the cheek.
You pick.
Suggest a full re-wire and give him a quote £5 less than the original cost, tell him he gets a £5 discount because he's a regular customer......problem solved and money in the bank :cool4:
