T
TailSpin
Hi All
not sure whether this question has been posted before so here goes :
An isolator on a control panel which feeds an inverter and on to the motor , the problem is when you turn off the isolator it does not kill all the panel some parts have a supply on them which then feed things like 230 volt fans ect .
I thought that once the isolate was off that should then kill the panel except my be for some control circuits.
any thoughts ?
regards
John
An isolator isolates whatever it's been designed to do, simple as, and should be labelled as such.
Hi All
any thoughts ?
regards
John
What equipment are you going to work on? is there not a local isolator next to the equipment you intend to work on?
Hi All
any thoughts ?
regards
John
Most of the panels I work on and build are designed as such and sometimes for maintenance purposes, the cables connected that remain live when panel is opened should be orange and can feed many things like stopping software crashes, panel lights and sockets for the engineer etc ....the list goes on, this is common practice and what is wrong here is probably the misleading title of the thread, you are not isolating here you are switching off sections of the power and control to allow for maintenance. An Isolator upstream of the panel would be for safe Isolation of the whole machine. (Assuming its fed off one supply).
My question is; Why are you in the panel if you are unaware of the regulations and practices that govern them? They don't fall under the BS7671 although some regulations are repeated in the BS7671 so if you are an Electrician the most you should be doing in this panel is connecting the power supply to it, anything else and your insurance will probably be void.
so get your sharpie out, then.
Is this a case of one isolator controlling only part of a machine, or is it a machine with two supplies?
To my mind there should be an Isolator whereby the whole machine can be switched off.
this is a standard panel you will come across.
power on one side and controls on the other, the controls will be fed from the supply side of the isolater.
now depending on the panel there are ways to isolate it via relays,fuses etc.
you shouldnt be touching any of these if you don't know what you are doing.
the isolator on the front is not usually designed to conpletely isolate the panel
it sounds like a bms/controls panel mate with the inverter in the panel etc.
i doubt it serves a single machine, the panels we work on always stay live because they are continuously reporting back to the estates/maintenance department.
I am in the panel doing maintenance works on the inverter , the main supply goes through a isolator but there is a multicore cable that feeds things like panel lights fans ect some are 230 volts so when the main isolator is off and they are very much on . I would just seem good practice to have these circuits isolated when the main switch is off . I guess it requires clear labels to warn of circuits still alive in panel when isolated .
Depends how old the panel is, any modern panel that meets requirements will be clearly labelled and usually have shields over any exposed connections that remain live or fingersafe at least with individual warnings, often common for power to run to an isolating Tx that feeds all the necessary's like maintenance lights and power etc, either way if your inside the panel you should still be knowledged in panel regulations and design so as not to put yourself at risk. If you hadn't noticed part of the system was still energised 'Its not always clear' then you could have been at risk of shock and the risk is higher with old panels that lack modern standards. Panel heaters are the most common requirement for tapping of the live side of the panel interlock, when the operator switches off the machine after his shift the panel still has protection from condensation.
I wasn't having a go at your competence just questioning it based on your query plus your lack of profile info so we have to ask; there are many hazards if you don't understand the practices and regulations of control systems regardless of you only making adjustments to say a VSD parameter.
There are clear specifications for allowing circuits in a machine control panel to remain live after the main isolator is switched off.
It is common practice, and is in accordance with the BS EN standard for machinery panels.
It is also totally acceptable, and necessary.
There is no issue with this scenario.
I belive there is an issue, if there is no warning that such is the case on a machine or panel that we have to work on or in.
I've seen isolators that should have been wired to BS7671 by-passed so as to provide power to parts of a machine even when the isolator is switched and locked off.
an isolator on the door of a control panel doesnt come under bs7671.
they usually say isolate elsewhere before opening
