Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
I really do appreciate Kate all your help and constructive feedback on this, it's an area that itself has had the regs fiddled with and also other issues like earth rods and distances to the building.
Ok so if we break it down into small chunks, let's hypothetically say we will go with the earth rod, it says connect it be k to the met. Do we have any information anywhere as to what reading is acceptable that we must achieve?
Top op of head moment:
take a 2 core SWA cable from the internal dist board using the sheath for the earth
terminate into a plastic isolator externally and RCD at this point
take another SWA from the isolator and run the cable underground to the new VCP.
Install this at least 2M from the metal building
earth the underground SWA sheath and the VCP by an earth rod and earth pit.
Test
it is a minefield eh?
It it is unusual for DNOs to provide earths to metal framed building is it not?
This is job may need a step back and reasses. Many heads are better than one.
Quite a few years ago I was part of a crew of agency sparks working on a new agricultural building being built on a farm, we were mainly responsible for installing the services in the building (lighting and power), another crew were sorting the supply to this building including the Earthing segregation from the main intake (PME) and installing the TT parts and all ground works.
The DNO were involved due to an upgrade of the supply for the increased demand.
Anyway to cut a long story short the DNO were unhappy about the proximity of this new metal clad TT building and extraneous parts of the PME bits, I don't know what the final outcome was as we were finished our contract, but I do know there was hell to pay at the time.
Test
i like the idea but there just isn't the option to do this unfortunately due to it being a car park immediately outside the building.
I seem to think this is going to be more problematic than planned for.
i think other than connecting the rod to the met there's probably not a lot of choice.
If any of you have the BYB can you take a look at
Annex A722, item A722.3, gives guidance on determining the maximum resistance required for the earth electrode in (ii).
New posts
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
