Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
I have no means to scan the ground unfortunately, can you rent them?
Yes mate. Please do.
Just a thought if he does TT it, it is close to a metal clad building which is itself TNCS/PME and also likely to be bonded via the structural steelwork , your are not supposed to be able to touch two different earthing systems simultaneously, this can itself be a shock hazard due to the differences between true earth (TT) and the PME earth.
I don't know the reg number off the top of my head, and it may be a DNO rule, I would have to look it up to back this statement up.
Not read all the threads, but SWA going though 2" wall shouldn't be a mess. Drill though wall at a steep angel ie 60 degrees.
it is a minefield eh?
It it is unusual for DNOs to provide earths to metal framed building is it not?
This is job may need a step back and reasses. Many heads are better than one.
Im going continuous now actually, you are not up to speed LOL.
Should a metal clad building be PME anyhow? I thought not.Just a thought if he does TT it, it is close to a metal clad building which is itself TNCS/PME and also likely to be bonded via the structural steelwork , your are not supposed to be able to touch two different earthing systems simultaneously, this can itself be a shock hazard due to the differences between true earth (TT) and the PME earth.
This was my other part of the jigsaw, its too close, and I know its bonded as have seen it all inside against the back of the skins.
Hmm its not very straight forward is it.
I say just connect to the PME system, its too close.
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
We use essential cookies to make this site work, and optional cookies to enhance your experience.
